Message 1 of 2
Unable to record
My BTtv remote will no longer record any programmes
1 REPLY 1
Message 2 of 2
Re: Unable to record
Hi @Critterbabe, welcome to the forum and sorry you're unable to record.
What type of BT TV box do you have?
Are you sure it's a problem with the Remote Control? If so you can Reset The Remote to see if that helps
Cheers
John
