Message 1 of 5
remote
Hi all, just set up my new bush tv, all good apart from my bt remote, the code works fine the only problem is it will turn the tv off but will not turn it on, tried new batteries, reset the remote but nothing, it's not important just annoying, any clues anyone?
4 REPLIES 4
Message 2 of 5
Re: remote
Might be worth having a look at your TV settings. For example, on my SONY TV there are settings for HDMI control - "Auto devices off" and "Auto TV on".  Might be similar for the Bush?
Message 3 of 5
Re: remote
tried that thanks Billy, it's definitely the remote, ah well, onwards........................
Message 4 of 5
Re: remote
Hi @quaos1 Thanks for posting, on some TV's you need to press the OK button to switch it on.
Neil
Message 5 of 5
Re: remote
no good, but thanks Neil
