Message 1 of 4
set top box not responding to volume controls from remote
As header. All other functions are working perfectly. But Ive got no sound and the volume up/down/mute are doing nothing. The blue light on end of remote lights up when I press them but nothing happens at the set top box.
3 REPLIES 3
Message 2 of 4
Re: set top box not responding to volume controls from remote
Hi @trevorsharp and thanks for posting.
Have you tried changing the batteries in the remote?
Cheers
David
Message 3 of 4
@trevorsharp
Which box have you got?
Typically those functions on the remote actually control the TV's volume etc if you've paired the remote to the TV otherwise I think they do nothing.
If you don't have the Pro box then when you hold done the AD button (bottom left on the remote) then using the volume up/down then controls the volume output from the box, this should always be 100%.
Message 4 of 4
I have this same issue and have used the AD button and volume can be controlled but the mute button is still not working. Any ideas?
