Message 1 of 4
unable to update your apps Bt box pro
Hi Like the previous 4k box I am now getting this message unable to update apps. With the 4k box a maintenance mode reset was the only thing that solved the issue. Would this be the same with the bt box pro if so how do I enter maintenance mode? Thanks.
3 REPLIES 3
Message 2 of 4
Re: unable to update your apps Bt box pro
Anonymous
Not applicable
Message 3 of 4
But if you're looking for ITVx, don't bother.
Message 4 of 4
Yeah don't see any difference from ITV hub
