Message 1 of 3
which box
Hi I used to sub to BT TV but was a little frustrated as we don't get the full Freeview list of channels where we live. Probably only get about 14! So have been with Sky for past 2 yrs.
I am just looking if anything has changed here at BT TV. If I were to come back which box would I get with the entertainment package? I notice the Pro box has some Freeview channels available on line?  Also would probably change my BB package to get best deal. Thanks
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: which box
Hi @MitoMan
Standard box now is the BT TV Pro and you can find a list of the IPTV “Freeview” channels you can receive without an aerial here.
Message 3 of 3
Re: which box
Thanks. That's good to know a lot more channels than we get via aerial. Will look into it further.
