Message 1 of 4
Installation damage
I live in a ground floor maisonette and I recently had super fast broadband installed. The engineer (who I think was actually with Openreach) drilled through an internal cavity by my front door to the outside of my property.  Over the weekend i've noticed a wet patch in the hallway underneath the entry point, this was accompanied by a very loud whooshing noise from the inside of the cavity when the upstairs flat unleashed the contents of their washing machine.  I have a horrible feeling that the engineer has drilled through the flat above's down-pipe. This would maybe explain why he was there for 6hrs on the installation date. What is the protocol in this situation, does anyone know?
3 REPLIES 3
Message 2 of 4
Re: Installation damage
@Hannyv81
Welcome to this user forum for BT Retail phone and broadband customers.
Are you a BT Retail Customer?
Message 3 of 4
Hi @Hannyv81 was it BT broadband that was installed? You can raise a case directly to Openreach on this link when damage is caused to your home.
Neil
Message 4 of 4
Yes I am
