Message 1 of 4
Reporting a probably scam call.
Here's a funny thing.  I had what I took to be a scam phone call.  I went to report it on the BT report-a-scam page.  That requires you to put in the phone number of the call.  I copied and pasted the number as it appeared in my Call Protect list of recent calls.  The report-a-scam page rejected it as not a valid number for my complaint.  So, weirdly, the report-a-scam page wouldn't accept as valid the very number that Call Protect recorded as the number from which my call came.
3 REPLIES 3
Message 2 of 4
Re: Reporting a probably scam call.
Hi there @PaulBrownsey
Thanks for coming back to the community.
You would need to enter the number without spaces or brackets, for example +44500999123. If you could try and enter the number again without copy and pasting in this format to see if the report a scam call form accepts the number?
Thanks.
Leanne 🙂
Message 3 of 4
I did that and still got the 'not valid' automatic response.
Message 4 of 4
No doubt because it was a spoofed number in an invalid format.
Reporting numbers is a futile exercise, scammers have a virtually infinite pool of numbers to use.
Basically, if you don't recognise a number, don't answer it.
