Message 1 of 5
STB Pro Remote
Is it just me that finds the Pro remote control has so many fewer operations than the basic STB?
Thx
4 REPLIES 4
Message 2 of 5
Re: STB Pro Remote
Why kind of functions do you want? Because I find the remote has all the functions that are required
Message 3 of 5
Re: STB Pro Remote
Thx, was looking for subtitles but found an answer blow. Will try it later.
Message 4 of 5
Re: STB Pro Remote
Okay, still can't find how to get to subtitles. Any help appreciated. Thx
Message 5 of 5
Re: STB Pro Remote
Hi @Flipflop96, have a look at the link below and let us know how you get on:
https://www.bt.com/help/tv/turning-on-subtitles-on-your-bt-tv-box#:~:text=You%20can%20easily%20turn%...
cheers
John
