Message 1 of 5
TUK TUK UK access
Trying to access the TUK TUK UK website but BT is not letting me do so. why ?  How do I get access through BT ?
4 REPLIES 4
Message 2 of 5
Re: TUK TUK UK access
If the domain is https://tuktukuk.com/ then it loads fine for me on BT broadband, do you perhaps have parental controls enabled and web protect ? they might be stopping you, I have mine disabled.
Message 3 of 5
Hi Richie
Complete novice. Where do I find parental control and web protection.
Many thanks  Pete
Message 4 of 5
You will find them by logging onto your MyBT then going to " Your Security".
Message 5 of 5
Success.
Many thanks to all.
Pete
