Message 1 of 8
Website not accessible via BT network
Hi,
My website is not accessible through the BT network.
I can browse the website with other networks but not with the BT network. I went through the other posts and some of them have a similar issue as I am facing right now. Two days ago my site was working fine and suddenly it stopped working with the BT networks.
PS: My site is amchur.co.uk
Can someone help me to fix the issue, please?
Many Thanks
7 REPLIES 7
Message 2 of 8
Re: Website not accessible via BT network
As the link is your business website, have you tried asking your web hosting company?
Its visible on my BT connection, so its not a BT issue.
Message 3 of 8
No problem accessing for me so BT are not blocking it.
Check that  your antivirus  isn't blocking it or that your BT Webprotect isn't blocking it.
Message 4 of 8
Hi,
I have asked the hosting company as well and they redirected me to the BT issue. Also, the site cannot be browsed from the VM network as well.
I tried to access the site with a VPN and it worked fine.
Many Thanks
Message 5 of 8
It works for me on BT broadband. If it's not working on Virgin Media there's clearly a problem elsewhere and your hosting company might just be fobbing you off
Message 6 of 8
I have no problem accessing it on a VM connection. It would appear to be a problem your end.
Message 7 of 8
I have emailed my hosting provider. Let's see what they have got to say.
Many thanks for your response.
Message 8 of 8
I can confirm it works fine for me using BT broadband, I can also confirm I'm now really hungry cause I started reading the menu 😞
