Message 11 of 13
Re: 0151 number
Thanks very much for the advice.
I quite agree that this system needs looking at carefully.
Message 12 of 13
Re: 0151 number
Tellows doesn't have it listed as a known nuisance caller, could it be a careline number
Message 13 of 13
Re: 0151 number
Thanks for the replies.
I'm waiting until my father's next bill arrives which should be imminent and see what the itemised calls are as I have been there looking after him up to and during Xmas and he has been in hospital since mid last week. Should then be able to see if connected to his Suresafe alarm which I think is to do with it - although as previous member said if this was the case- as a duty of care they should be contacting me every time it happens!
