Message 1 of 8
ASDL/VDSL
I was in touch with BT yesterday to get the details for setting up my third party router. I have FTTC. They said my line is ASDL, however I thought it was VDSL, can anyone chime in to clarify?
7 REPLIES 7
Message 2 of 8
Re: ASDL/VDSL
@FlusterCluster
Welcome to this user forum for BT Retail phone and broadband customers.
Login to your BT Account, and it will tell  you what broadband package you are on.
https://home.bt.com/login/loginform
Message 3 of 8
Re: ASDL/VDSL
I feel bad for asking as that is quite an obvious answer! I checked the app but info there is quite limited and didn't even consider logging in to my account... Thanks @Keith_Beddoe
Message 4 of 8
Re: ASDL/VDSL
If you have FTTC it is VDSL
Message 5 of 8
Re: ASDL/VDSL
Yep, turns out it is VDSL. I haven't set router up yet but I'm beginning to wonder if the details I was provided with are correct... I will try and get it up and running and if it doesn't work, I'll be back with another post.
Message 6 of 8
Re: ASDL/VDSL
Details are PPPoE with username [email protected] and password BT VLAN id 101
Message 7 of 8
Re: ASDL/VDSL
I have the username/password details. That's another thing they gave me totally different info. Told to use [email protected]
Have checked forum for other users with same router and think I have all the info needed. Thanks all.
Message 8 of 8
Re: ASDL/VDSL
@FlusterCluster
You can in fact use anything @btbroadband.com
