Message 1 of 3
Account properties/email address
Apologies, I suspect this is the wrong board but I went with a best match.
I am trying to change my username to my current email address.
I can set the recovery address to this updated address no bother.
I can change my username to any other email address/domain I have.
However, even after changing the recovery address back to another I own, I cannot set my login address to be my new email address.
I suspect the issue my be that <account>@<something>.email is not recognised as a valid address and the same validation isn't happening to a recovery address?  But that may be nonsense.
Anyone advise or help?
Thanks!
andy
2 REPLIES 2
Message 2 of 3
Re: Account properties/email address
I have assumed that you are referring to your BTID when you say you want to change your username?
If that is correct see the following link
Can I change my BT ID security question and answer? | BT Help
Message 3 of 3
Thanks for the reply.  Appreciated.
However, the problem is that I can change the BT ID address to any other I own at  <domain A> easily but not to an address at <domain b>.  I can't save that change.   I can use an address at <domain B> as the recovery address without issue.
[email protected] is fine for the BT ID.
[email protected] is not accepted for the BT ID.
[email protected] is fine for the recovery address.
Thanks.
andy
