Message 1 of 8
BT Data Greece
I have purchased Data for Greece  £11.33 for the month of June 2025.
How do I check this?
7 REPLIES 7
Message 2 of 8
Re: BT Data Greece
I would try MYBT and mobile and see if it has been added
Message 3 of 8
Re: BT Data Greece
HOW DO I DO THIS IN THE MY BT APP?
Message 4 of 8
Re: BT Data Greece
if you go to MYBT then my products then mobile and check there
Message 5 of 8
Re: BT Data Greece
Hi @andreaferns120472  Did you manage to find your add on after following @imjolly's advice?]
Chris S
Message 6 of 8
Re: BT Data Greece
I purchased this with EE
Message 7 of 8
Re: BT Data Greece
Hi @andreaferns120472.
Are you an EE mobile customer?
Katie
Message 8 of 8
Re: BT Data Greece
if you bought the add on pack from EE then it reasonable to assume you are an EE mobile customer (it would have saved some time if you had included that in initial post) and should look into your EE mobile account on line
