Message 1 of 5
BT ID Username
How can I get my BT ID Username changed, I have tried online but it will not let me. My current BT ID Username will soon be ceased and I need to change it. Can this only be done by BT, and if so how do I apply.
4 REPLIES 4
Message 2 of 5
Re: BT ID Username
Hi @XF1breBuilder, welcome to the forum and sorry you're having trouble changing your username.
Check out the steps on: Changing your BT ID username and security details | BT Help and check the steps to change the username and let us know how you get on.
Cheers
John
Message 3 of 5
Re: BT ID Username
I assume your BT ID is based on an ISP's email address? The username will remain the same for the BT account ... what you need to change is the Contact Email Address in your account - the BT ID can remain the same.
The link below should hopefully take you to the right place where you can change the email address:
https://my.bt.com/s/apps/appsselfserve/index.html?/profile#/profilereview
Edit: I was typing as John replied ... his advice takes priority. 🙂
Ian
Message 4 of 5
Re: BT ID Username
thanks that is all I needed to know
Message 5 of 5
Re: BT ID Username
thanks John
