Message 1 of 3
Billing
hello! I cannot login to my account - I keep being directed to email page? It won't move past the login page each time I try? Can anyone help?
2 REPLIES 2
Message 2 of 3
Re: Billing
Are you sure you are using your BTID and password as it sounds like you are using email login and password
Message 3 of 3
Re: Billing
Doh! Yes thank you for your help!
