Message 1 of 5
Broadband in an annex
Hi,
I am aware that if you place an order for broadband only, then an existing landline on the property becomes defunct. I live in an annex on my landlord's property - is there a way to get broadband to the annex without affecting their landline?
For context, the landlord's existing broadband barely reaches us over WiFi and has average speeds of 750kb/s, but upgrading isn't an option.
Thanks for any input.
4 REPLIES 4
Message 2 of 5
Re: Broadband in an annex
@ButlerD
Welcome to this user forum for BT Retail phone and broadband customers.
Unless the annex has a separate address then its not possible to order your own connection.
Assuming your landlord is a BT Retail customer, could you run an Ethernet cable from a port on the BT Home Hub, to the annex, and use that, as it would be much faster.
Message 3 of 5
You can just order your own service from another supplier, just make sure they are fully aware that it is a second service to the property and not a takeover of an existing service.
I would have thought it was also possible to order a second service from BT
Message 4 of 5
The problem is that it would be tied to the landlord`s address, and correspondence would go there, which could cause problems. There is a high possibility of it going wrong.
Message 5 of 5
As will any other correspondence the OP receives.
