Message 11 of 38
Re: Broadband switching without notification / knowledge / consent
Thank you. Not sure, the text notification said the engineer needs to go to the cabinet, not our property.
Message 12 of 38
Sounds a bit odd , unless you had ADSL broadband previously (that’s delivered from the exchange) and are getting FTTC ( fibre to the cabinet ) broadband, then the visit seems unnecessary….just for clarity you said telephone is back albeit with a different number , but you also said when asked which was more important restoration of broadband or restoration of telephone toy said broadband, so do you have your broadband service restored or not ?
Message 13 of 38
Sorry for the confusion. Yes, we have a telephone line restored with a different number. We do not have broadband restored. When asked about the priority, it was either broadband or getting our original landline number restored.
Message 14 of 38
At least it wasn't some random inputting the wrong address that was the cause of your problem.
Interesting however to see the intial rush of blame on One Touch Switching without actually knowing the facts or extrapolating information from the intial report because that's the only info they have at the time and it's completely convenient to lay the blame there. Unfortunately, this happens all the time in life. OTS might occasionally be a problem, but probably only because someone is incompetent enough to not look at what they're doing when they initiate the switch.
I've recently done One Touch Switching without a single hitch, all completed within 5 working days. I even managed to input my own address correctly! No interaction whatsoever between me and BT other than them sending out their obligatory emails. I also don't have the additions of expensive TV packages or a landline that so many people seem to insist on having but seemingly rarely use, so I guess switching for someone in a similiar situation to me using OTS would be relatively simple.
I know plenty of people who for some strange reason, still keep a home landline for 'Just in case' purposes but then it just sits there doing nothing, unused, a pointless relic of the 20th century that only rings when spammers call. Still, if it keeps people happy, then who am I to criticise! I get it that there's a lot of 'elderly' folk out there who apparently 'need' a landline, but I know plenty of older folk who don't 'need' one and happily do without it.
And as an end piece, loyalty usually, rarely pays. So for those folks who have been with their utility provider for a quarter of a century and then suddenly realise they've been getting caned for years on payments, you've only got yourselves to blame. But it's all about amazing service isn't it?
Message 15 of 38
... there had been a switching request placed on 12/07. However, we hadn't made a request nor had we been notified of any request, and certainly not given any consent. ...
The theory from both operators was that someone has entered the wrong address (ours) when switching providers or setting up a for the first time. That might be the case, but I am curious how it can happen without me being notified? No text, no email, nothing
I can't help with your problem,  but this seems to be what is happening to us and it sounds as if it might not be uncommon. BT assured me on Friday that it had been resolved but I have little confidence in the reassurance. (I have already posted about this.) I am beside myself with anxiety and can't sleep.
Having a landline is not just about elderly people who don't like change. In many circumstances I can't see my mobile phone. I am horrified that we could lose all our services without our consent.
Message 16 of 38
  • The OP has since stated in a subsequent post that it wasn’t an erroneous switch initiated outside of BT?….
Message 17 of 38
Yes, but comments elsewhere in the thread indicate that this problem of switching without consent does exist and Ofcom's 'simplification' has caused it to multiply.
I said that what he initially described is apparently happening to us, without our agreement.
Message 18 of 38
I assume when you state “Ofcom’s simplification” you are referring to One Touch Switching?
I myself have switched using OTS without problem. I agree though, I guess it would be entirely possible someone could initiate a switch through their own complete incompetence by inputting an incorrect address for example.
it would be interesting to see published factual data for how many unauthorised/erroneous switches have actually occurred since OTS was introduced before we place the blame on OTS.
Message 19 of 38
Oh, it's more common than you think.  I moved into a new build 35 years ago and the post office, (bless 'em), told me the post code was 7AB instead of 1AB*.  Was 12 months before someone identified the issue.  Another example is I live in Myplace Close*.  The next town has a Myplace Road.  I used to have taxis turn up for Myplace Road regular.  So, it does happen.
*Those are not the actual names, of course, but show the same mistake.
Message 20 of 38
I wonder whether it occurred to Ofcom that someone could initiate this maliciously.
