Message 1 of 8
Broadband upgrade to full fibre
Upgraded our Broadband to full fibre on 18 September and was told an engineer would visit in the next few days but this did not materialise.  Subsequently I got several contradictory messages about a visit but still no one turned up.  Contacted BT only to be told to ignore the information on our account and that they couldn’t tell us when an engineer would visit and only that “next review” whatever that is will take place on the 22 October.  So I have no idea when our broadband will be upgraded and am stuck with paying the old broadband charges which are much higher than the new contract and a landline I don’t need.  When I complained to BT they said the complaint had been resolved as it was their third party suppliers  problem.  So I have no idea what is happening ! All very unsatisfactory.  If I had known about these problems at the outset I would have gone elsewhere.
7 REPLIES 7
Message 2 of 8
Re: Broadband upgrade to full fibre
Good morning @AR02.
I am sorry to hear your Home Broadband upgrade has not yet completed.
Did the team advise what has stopped the upgrade going ahead and what the review is on the 22nd October?
Katie
Message 3 of 8
Hi Katie
no they didn’t provide any information at all!  I have no idea what is happening.
Anne
Message 4 of 8
Thanks for getting back to me @AR02.
I understand this must be very frustrating.
We are limited to what we can do here on the community without account access.
I would absolutely recommend getting back in touch for a full understanding on what the review is for on October 22nd.
Katie
Message 5 of 8
Thanks.  I have already lodged a complaint under VOL013-892242485315 with David in Belfast but he said he had to mark it as “resolved” even though it hadn’t been resolved which is quite ridiculous!  I followed this up in writing to your Consumer Resolutions department but have not received a notification or response.
Anne
Message 6 of 8
How were you notified that FTTP was available ? , have you seen any work in your area recently by Openreach or its contractors upgrading the area to FTTP .
The way CP’s ( communication providers ) like BT interact with Openreach is limited by the rules Ofcom the regulator impose , but , if for example OR stated an area as accepting FTTP orders but that was inaccurate,  BT could be offering something that’s not actually available.
Enter your address here and post the results, especially the survey information , an example is shown below, yours may be different depending on the way the current copper pair service is provided, the example is for a modern ducted property
https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG Feed with no anticipated issues.
OR can state FTTP available when a considerable amount of work is still required, if your survey is something like ‘partial DIG’ , and KCI2 ( two stage installation ) in the installation process , then Openreach still  have work to do , that’s only undertaken once an order is received, any date given initially is really only an advisory date for Openreach to arrange the remaining work ( the first stage of the two )  , the actual appointment date is only given after this first stage work is done, CP’s don’t seem to communicate this very well , and Ofcom rules mean Openreach are not allowed to advise you directly …..if things like road closures are required the delay between stage one and stage two can be significant.
Message 7 of 8
Iniltous thank you for the information and the results are outlined below of the survey.
WBC FTTP Available.  FTTP an install process - Stage 1.  Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG congested duct.
i contacted BT last week and was informed that between the 17th and 22 October Openreach would contact me to arrange an appointment.  To date no contact has been made.  To be honest I can’t see this materialising.
Message 8 of 8
There is something of a contradiction in the survey information, if Openreach suspect the the duct to your property is congested ( blocked ) then it’s normally a 2 stage installation process ,the first stage to deal with the potential duct issues , the second stage to complete the installation, however the ‘congested duct’ note is usually an educated guess , often the duct is fine , but it’s better to be cautious and indicate its needs checking ….so it odd yours is single stage installation and congested duct .
TBH , the first stage doesn’t always need you to be home but it depends , having someone available is preferable , if all OR need to do is confirm the duct OK your attendance isn’t needed ,and may have been done in your absence , but if unblocking it ( should it be necessary ) needs excavation in your garden then someone at home to give permission is required, obviously this date should be confirmed, but as Openreach don’t converse directly with consumers, it’s BT that need to advise you when OR going to visiting you , it’s the usual OR advise BT , BT advise you .
