Message 1 of 15
Bt App redirecting me
I downloaded the BT app and logged in, but it keeps getting to the pin page then before I can continue it redirects me and asks me to finish setting up my account and add the my BT APP
Whats does it mean I’m so confused!
any help would be great!
Tags (2)
14 REPLIES 14
Message 2 of 15
Re: Bt App redirecting me
Hi @AzzaBazza
Welcome to the community.
Are you able to log in OK on BT.com? It may be easier to finish the setup on there, then log into the app after.
Please let us know how you're getting on.
Chris
Message 3 of 15
What do you mean finish the setup? As far as I’m aware the set up is already done?
Message 4 of 15
@AzzaBazza @Christopher_G Spoke to a "Guide" at BT and to someone in technical support on 11th May after I was unable to access my latest bill. Wasn't working on either web or app and kept getting sent back, after various 4 digit pin numbers being texted, to the black and white picture of the telephone exchange switchboard. Was told there is an issue with accessing MyBT etc and they were working on resolving it and to try again in a few days!!
Message 5 of 15
Hi @PB55 @AzzaBazza
Thanks so much for letting us know you're struggling with accessing the My BT app currently. I'm going to send over a Private Message to grab a few details.
Linzi
Message 6 of 15
@AzzaBazza @Christopher_G @Linzi_H . It looks like BT have resolved the problem both on MyBT app and the BT.com Web version. You will need to go to Google Play or Apple App Store and download the latest update which should change your MyBT. I downloaded the updates at 17:30 this evening (13 May) after signing in etc I can now access the new version of the app and all my account details and no more pictures of the old telephone exchange.
Message 7 of 15
Hi @PB55
Thanks so much for the update and for sharing the steps you followed to fix this.
We really appreciate it!
Linzi
Message 8 of 15
This has not worked for me
Message 9 of 15
Hi @AzzaBazza
Thanks for letting us know. I can see @Leanne_T has been in touch with you directly to discuss the next steps.
Linzi
Message 10 of 15
I'm having the same problem, please help.
