Message 41 of 56
Re: Can not view my bill or useage online
@gg30340  Well it’s all about opinion isn’t it? You state you weren’t taunting me, my opinion is, that’s what it looks like to me.
You clearly didn’t read the post that obviously irked you in its correct context (my opinion) and in my view, decided to take it to a different level.
As I say, I genuinely don’t care what you think about my posts, but at least if you’re going to respond and react, read the structure of the post correctly.
Message 42 of 56
There you go again making assumptions. I clearly did read your post, more than once, and I stand by what I said.
I was  not at all "irked" by what you posted, I was interested where you got the information that you posted. Thank you for clarifying that it is not based on facts and is just your opinon.
I did not take it to a different level. You did that in your last paragraph of message 37 . I asked a question which apparently you didn't like the question or you didn't like the fact that I asked a question either way that is your problem not mine.
As for you genuinely not caring what I think of your posts, I have already covered that.
Message 43 of 56
Thanks 😂
Message 44 of 56
Why is it saying `Solved`, which this issue clearly is not solved!
Message 45 of 56
I have no idea why it is saying "Solved" as I mentioned in my earlier posts I would let you know how things are progressing
Message 46 of 56
Can I ask where you see"Solved"?
Message 47 of 56
I assumed it saying solved as on of the message says the following.......
If you can log onto your account there is nobody on the forum including the moderators can access your account to check what the problem is.  Unfortunately you will need to continue to  contact BT Billing 0330.1234.150
Message 48 of 56
Issue still there this morning so I don't expect it to be fixed over weekend so will be contacting Ombudsman on Monday with the various screen shots to underpin my case and will post how complaint progresses.....
Message 49 of 56
Most likely one of the moderators put this down as `Solved` when it is clearly not.
Any moderators out there, please remove this as `Solved`, because the issue is still there.
Message 50 of 56
Just an update on the issue. Nothing has changed with regards not being able to view my bill etc. It is now coming up on 4 weeks and the communication Ombudsman online intervention request form specifically says 6 weeks before they will take anyaction so once that time period is up then I will be back on to log my complaint.
Regards
Steve
