Message 1 of 5
Can't activate TNT on Discovery Plus
I ordered TNT Sports via BT last night but I can't get it to work in the Discovery Plus app.
I tried to activate it but it takes me through then says contact BT.
I can watch using the BT Sport app but that closes soon.
Can anyone help?
Chris
4 REPLIES 4
Message 2 of 5
Re: Can't activate TNT on Paramount Plus
I believe its Discovery+ you need to activate it on
Message 3 of 5
Yes, apologies, that's what I meant, Discovery Plus
Message 4 of 5
Re: Can't activate TNT on Discovery Plus
Check out the instructions at www.bt.com/sport/discovery-plus
If the option to activate doesn't appear in MyBT then email me at [email protected] with your BT ID and BT account number, and I'll sort it.
Message 5 of 5
Hi, I have emailed the details
