Message 11 of 16
Re: Can't order broadband
I've figured it out. It's to do with the address.
We have an Open reach socket/line installed ? (Incorrect terms I think). Address is selectable on the menu but I then get stuck in the loop. I tried with my parents address and the order went further .
Incredibly frustrating
Message 12 of 16
Just to be clear , BT can’t have exclusivity on Openreach , it’s not allowed , so where did you get that impression ? , and who apart from BT (and  include EE and Plusnet )  have you even tried ? ,
if Openreach did some sort of deal with BT Group to only have BT companies available by design , it clearly disadvantaging others (like Sky , Vodafone etc ) and the regulator woukd be all over it , they aren’t because it’s not happening.
Message 13 of 16
BT are the only provider that are showing our address in their Search function. I'm well aware there isn't a monopoly
Message 14 of 16
@imjolly @licquorice thank you both. I had also tried those paths and the same thing . It's due to the fact BT weren't showing an error that they can't supply our address (doesn't seem like anyone can at the moment).
Message 15 of 16
is you address correct (exactly) on the royal mail database?
Message 16 of 16
Yes. I contacted the council who in turn updated Royal Mail and I can find it on their PAF database. I think I need to get the address set to Gold through Openreach first and possibly check with Ordnance Survey to see if they have it registered too.
I know YouFibre use a different network (Netomia?) but they haven't updated their address list yet either.
Might take a little while to do.
