Message 1 of 3
Change from Exchange Only to FTTC
Hi All,
We have been having issues with our broadband dropping out on a regular basis and have had new equipment telephone lines and numerous engineer visits. We are currently on an Exchange Only telephone line and I was wondering whether we could switch to FTTC or FTTP.
we live approximately 50m from the telephone exchange and there is a green cabinet in the street which other properties are connected too and can access FTTC to their properties.
Any advice would be much appreciated as we have been having issues for the last few months with no solution in sight.
Regards
2 REPLIES 2
Message 2 of 3
Re: Change from Exchange Only to FTTC
enter your phone number and post results  this will show what is available to you
Message 3 of 3
Telephone Number 0194****** on Exchange PREES
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 17 -- 10 to 19.5 Available --
Up to 17 Up to 1.5 10 to 19.5 Available --
Up to 7.5 -- 6.5 to 8 Available --
2 -- -- Available --
SOADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) WBC SOADSL Availability Date Left in JumperWBC SOADSL 2+SOADSL MaxSOADSL Fixed Rate
Up to 17.0 -- 10.0 to 19.5 Available --
Up to 7.5 -- 6.5 to 8.0 Available --
-- -- -- Available --
Observed Speeds ADSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
24.38
1.09
2024-06-05
Other Offerings Availability DateADSL Multicast
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
20-05-2024
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
Y
N
FTTP is not available.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
