Message 1 of 2
Changing tariffs
Hi hive mind
I currently have a BT broadband package ending July 2023.
Can I change to a different BT tariff before my current on ends?
1 REPLY 1
Message 2 of 2
Re: Changing tariffs
You can change packages and promotions at any time during the minimum term, you will need to renew when you do so depending on the change but there's no fee for doing so and you'll be given all the terms before agreeing to any changes.
