Message 1 of 6
Delete old accounts on MyBT login
I am trying to change my address but when I log in I’m automatically taken to an old account.
I have two old unused accounts on my profile
please help me to delete them so I can get on with my move!
5 REPLIES 5
Message 2 of 6
Re: Delete old accounts on MyBT login
Hi @Sarabeth and welcome to our community.
If you have another email address you can set up a new BTiD but if that doesn't suit I can look into this for you. Just check your inbox for my message and drop me over the details.
Cheers
David
Message 3 of 6
Thanks David. I do have another email address I can use. Is it quite straightforward, just starting from scratch?
Message 4 of 6
Hi @Sarabeth, yes it should be simple. Go to Create BT ID and using your other email address input your active account number and it should take you through the registration process ok,
Cheers
John
Message 5 of 6
All done!! Thank you David 😊
Message 6 of 6
Thanks John 😊
