Message 1 of 5
Download File Size
Hi, I recently bought some music software which was a 39GB download. Until now, I’ve been able to download most files without a problem, most of which were about 5-10GB. For some reason, downloading this particular file, I get to around the 30gb and it stops, which obviously results in a failed download.
I’ve tried different browsers, different computers, but always the same failed download around the same 30gb mark. My question is, is there a limit on the size of the file you can download?
I have the BT fibre 2 package
kind regards
4 REPLIES 4
Message 2 of 5
Re: Download File Size
Nope. There are no limits at all. So if you're hitting a barrier, it's probably being caused by something on your PC
Message 3 of 5
If it was me, I would contact the website and let them know there is an issue with their download.
Message 4 of 5
Have you tried downloading a large file from a different source.
There are sites on the Internet that offer large files in order to test.
Before using any of the sites make sure that they are reputable sites.
Message 5 of 5
Do you have any scheduled tasks running on your PC(s).
e.g. does an antivirus software do scans after a preset period of time? ......This can cause a load on the processor. You can disable auto scans on Norton, for example.
Also does your PC time out on a set period of what it thinks is inactivity?
A clue to the problem is to check the timing where the download seems to stall.
