Message 1 of 3
Equipment Return
Hi,
I need to return my BT Pro box and have received the returns bag.
I have lost the packaging and any bits that it came with due to a house move.
So do I just put the BT Pro Box, Remote and HDMI lead in the return bag loose?
Thanks.
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Equipment Return
yes that will do
Message 3 of 3
Hi @Dfj1983, @imjolly is correct and that will suffice. Just remember to get a proof of postage and keep it safe until the box is marked as received back so you don't incur a charge.
Cheers
John
