Message 1 of 13
Home move, no engineer!
I booked my house move and the engineer is scheduled for today, but not confirmed. I had one open reach email saying there were issues, then no communications at all.
Is this normal? Why have they not contacted me either way?
Whats the best way to get in touch with them?
They texted on the 16th dec to say external work was needed, and would be in touch withing 8 days
12 REPLIES 12
Message 2 of 13
Re: Home move
@natswright
See if anything is shown in the notes on this page.
Use the address checker on the page below, and post the results, but edit out your address details first, but leave the exchange name and cabinet number showing.
Please include all notes at the bottom.
It should indicate if there is a potential issue.
You cannot contact Openreach, only BT.
Message 3 of 13
Re: Home move
It wont accept my telephone number and I have no idea what the other fields are...
Message 4 of 13
Re: Home move
@natswright
Use the Address checker option, as shown below.
Message 5 of 13
Re: Home move
Ah, thanks, I get this information?
Message 6 of 13
Re: Home move
@natswright
That indicates FTTP is available, single stage.
Is it a new build you have moved into?
Is there an Openreach ONT already installed?
Message 7 of 13
Re: Home move
Yes, 8 years old, but pretty new. The house has Virgin Fiber and a BT box on the outside of the house
Message 8 of 13
Re: Home move
So the property is fed by copper at the moment. Perhaps Openreach did not have a spare ONT?
The optical fibre would normally take the same route as the copper. They may have visited first to see if they can get the fibre through, and discovered a blockage.
https://www.openreach.com/help-and-support/full-fibre-broadband-installation-checklist
Perhaps the Virgin Fibre is in the way, also a Virgin ONT may be present inside.
Message 9 of 13
Re: Home move
On the phone now, seems the order was messed up, so it needs cancelling and placing again....
Message 10 of 13
Re: Home move
And I bet they will force you to move to EE, and offer more than you need, that seems to be the way things are going, all commission driven.
