Message 21 of 23
Re: How can I get someone to fix openreach records?
@PaddyB thank you, replied!
Message 22 of 23
Do keep this post updated, will be good to see the outcome of things like this.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 23 of 23
So... It has been fixed!
I did send a complaint at the same time I initially posted here, and someone has been in touch from BT to do the same thing I guess (ORDI) but I am not sure if it was the complaint person or the mod from here that made it happen, thanks to both though!!
I have not been contacted by anyone yet, just was checking the btwholesale checker daily and it is updated now correctly!
