Message 1 of 7
How do I download my bill
How do one download the bill online ie bills i have paid
6 REPLIES 6
Message 2 of 7
Re: How do I download my bill
How far back do you want to go? MyBT allows you to go back 12 months
Message 3 of 7
Thanks for quick reply just with in the last two months
Message 4 of 7
Login to MyBT and click on "Your Bills And Usage" below the BT logo
Message 5 of 7
Log onto your MyBT then go to "Your Bills" and once there select the date you are looking for to see it.
If you want to download it go to Billing History and either view it or download it as a PDF.
Message 6 of 7
I tried that it only show me Dec 2023 bill eventhough i paud my last bill everyday abd every month since Dec 2023
Message 7 of 7
Did you go to "Billing History" then in the two boxes at the top of the list select the number of months you want to view and click on the "Apply Filter" button?
