Message 1 of 5
How to get two names on bills?
Hi all,
For a universal credit application, I need to get a utility bill with both my name and my wife's name.
How do I edit / alter my account to enable this?
Is it something as simple as changing my first name to "[mine] & [wife's]" or is there a better way?
I have added my wife as an account admin, and have tried to navigate the maze of help topics/account admin without success so far.
Thanks for any help!
Tags (1)
4 REPLIES 4
Message 2 of 5
Re: How to get two names on bills?
@Pegasus-185
The bill can only have the account holder`s name shown on it.
Message 3 of 5
Thanks 🙂
Message 4 of 5
@Pegasus-185 wrote:
Thanks 🙂
I think that may be the case for other utilities.
You may be able to provide two separate utility bills with different names, if your wife has a utility in her name only, provided the address is the same. This would of course, not apply to BT.
You would have to check that with the DWP.
Message 5 of 5
The cynic might say that this is the DWP being "difficult by design"
