Message 1 of 5
Installation and Home Tech Expert cost
I've been wanting to order a BT broadband deal but I don't know if the Home Tech Expert install is something I need to add to the order because it says this in the details about it, so will I need to add this to my order as well or will an Openreach engineer already set me up fine with no extra cost?
4 REPLIES 4
Message 2 of 5
Re: Installation and Home Tech Expert cost
@JoshH1
Welcome to this user forum for BT Retail phone and broadband customers.
Copper based broadband is self install, and unless for any reason you do not have a phone socket, an Openreach Field Technician will not visit unless it fails activation.
This would not cost any extra.
A home Tech Expert is optional if you want someone to setup all your devices.
Message 3 of 5
Thanks for the reply, I'm looking to order a full fibre deal with the complete wifi disc and we have a phone socket, so will that mean an engineer will do everything necessary to have internet access?
I won't need a home tech expert unless they setup the hub to enable internet access.
Message 4 of 5
@JoshH1
A full fibre connection does not use your phone socket, its totally different and does need a visit.
See https://www.openreach.com/help-and-support/full-fibre-broadband-installation-checklist
Message 5 of 5
Ah I see, thanks so much for the help!
