Message 1 of 5
Landline rental
Is line rental included in the fast fibre pricing on the BT website?
4 REPLIES 4
Message 2 of 5
Re: Landline rental
if you order a broadband and phone package that includes the line  you can then select a call package either PAYG or unlimited calls
Message 3 of 5
Re: Landline rental
Many thanks 😊
Message 4 of 5
Re: Landline rental
Can you point me to a broadband package that doesn't include a line? Asking for a friend.
Anonymous
Not applicable
Message 5 of 5
Re: Landline rental
It's not entirely clear what you're asking, largely because of the mishmash BT have made of terminology.
Line rental is no longer billed separately & is included in the broadband cost. That is simply the method by which broadband is delivered, regardless of whether it's copper, fibre or a combination of both.
A landline is a different entity & would be the ability to make/receive calls. That would be an additional charge.
