Message 1 of 12
Landline useage - 700 mins package - start & stop dates
Hi,  we're on the 700 mins package & would like to know what date BT run our useage to and from. Does this differ each month?
We did ask a lady at BT but she couldn't explain this.
11 REPLIES 11
Message 2 of 12
Re: Landline useage - 700 mins package - start & stop dates
Almost certainly will reset on your billing date. Log onto MyBT > Your Usage & it should tell you when the usage data resets.
Message 3 of 12
Lasts 30 days (min contract) then renews automatically for another 30 days unless cancelled/changed. My BT is the place to look.
Message 4 of 12
Thanks very much for your reply.
So just to confirm, if the billing date shows 20 March 2022 we would expect the 700 minutes to refresh on the 20th of each month?
Message 5 of 12
Sorry, I can't confirm as I don't use the landline. But that's how mobile is billed so I'd be surprised if it's different for landline. But you should also have access to historical usage on that page, which would confirm reset date.
I can't see it being a strict 30 days as that would play havoc with billing. But this is BT, so something being illogical doesn't mean they wouldn't do it.
Message 6 of 12
No, cos there's 31 days in March so I wud expect it to renew on 19 April.
I've also just recently got the 700mins calling plan and this is based on the info I've seen, but always best to check with My BT 😊
Message 7 of 12
Message 8 of 12
Thanks 🙂
Message 9 of 12
Thanks - we pay 1/4ly but the 700 mins is monthly I think this is where our confusion stems from! Thought we'd cracked it last month but discovered yesterday that we haven't. Will crack it eventually - determined not to go over the allowance 🙂
Message 10 of 12
Yes, my apologises! It is monthly. Got confused with another Plan. 😊
