Message 1 of 5
Leaving BT
I’m going to move to Plusnet and port my phone number to a voip provider.
Should I sign up with Plusnet full fibre and the voip service at the same time or get the voip service first and then place the order for BB with Plusnet?
I’m currently on FTTC with BT and had an email from them saying I have to contact them about the switch over to digital voice or they will temporarily suspend my broadband.
I had the same email from them back in September and they were supposed to upgrade my line to FTTP and digital voice on 3rd November but it was cancelled
They also sent my a battery backup and VoIP phone which are both unopened and I don’t want them anymore.
What should I do?
4 REPLIES 4
Message 2 of 5
Re: Leaving BT
Why if you are on ‘ordinary’ FTTC with BT , would you be getting the communication about temporary broadband suspension, instead of them simply migrating you to DV as they have done on the vast majority of telephone customers that have broadband ?
Porting your number will cease your broadband as broadband can’t exist without a phone number (prior to SoGEA with DV ) , there may be a break before PN can ‘reinstate’ your broadband, migration of your broadband to PN surrenders your phone number but that number remains available to port for 30 days afterwards, so the way to best guard against some break in your broadband service would be to migrate your broadband to PN , and immediately after it’s changed over  , contact the VoIP provider to recover the phone number ( in the 30 day window ) however , because there presumably is some idiosyncrasy with your setup (otherwise why the BT communication saying your broadband would be suspended) I’d be suspicious that this won’t be straightforward as something is flagging your service are non standard.
The communication about broadband disruption unless you call BT ,  usually indicates the broadband and phone are from different suppliers so two separate bills ( this is SMPF , shared metallic path, popular 10-15 years ago ) , or it’s ADSL broadband (not FTTC ) or there is some indication on the account that an incompatible product may exist (like Telecare / fall alarm type service for example )
Message 3 of 5
Re: Leaving BT
I would port your number first as that will end your existing BT broadband and phone contract and then you can switch to Plusnet for broadband
Message 4 of 5
Re: Leaving BT
Because they were supposed to be upgrading me to FTTP and digital voice on 3rd November but it was cancelled for some reason.
I got the same email in September and had to ring them to arrange a appointment for the upgrade.
Message 5 of 5
Re: Leaving BT
Yes I think I’ll do that. I’m not in a contract though.
