Message 1 of 14
Moving Into a Home That Already Had BT
Hi All,
We are moving home on 20th August. When trying to place an order it states there is an existing provide open order on your account.
I assume this is because the current people living there have an account closing down, as we know they are with BT.
It states we can place an order from 21st August.
Does anyone know how quickly it is likely to be set up? Is it a simple case of they can make the service active instantly remotely, and we just need to wait for the hub and account details to be posted to us, and once plugged in a set up we should have broadband instantly?
Many thanks.
13 REPLIES 13
Message 2 of 14
Re: Moving Into a Home That Already Had BT
The open order is on your account not the other person's account.
Call BT Billing 0330.1234.150 to see if they can have the order removed or at least explain what it is for.
Anonymous
Not applicable
Message 3 of 14
Your patience is an inspiration...
me ,I'd tell them sod it Im off to a isp that actually wants my business
Message 4 of 14
Hi,
Called and apparently the open order is becasue the line is pending cancellation as the current home owners are closing their BT account.
This is pending for 20th August which is our sale completion date and we can't place an order until 21st August.
But could be a few weeks before it goes live.........
Would we be better getting a diff provider who can try to activate on the actual 21st?
Reason for choosing BT is becasue apparently fibre and speed are not great in the area we are moving to. Norwich, NR13. So thought be quicker amd easier to go with the current provider. Guess not!
Message 5 of 14
It will be the same Openreach line and speed whatever provider you choose.
Message 6 of 14
Are you presently a BT customer and if so are you using the Home Move procedure?
If you are a BT customer and still in a fixed term contract if you cancel your BT account you will be hit with cancellation fees.
Message 7 of 14
Hi,
No not with BT.
With a provider who cannot offer a port, so will be starting as a new customer
Just tried to see plusnet sign up and activation date is 28th Aug. Perhaps I should have done this sooner.
Just assumed could get up and running quick by going BT as the current provider for the current owner.......
Message 8 of 14
It is Openreach that provide the fibre service to all broadband companies unless there is an AltNet company available which uses its own infrastructure. This means that you will be working to Openreach's schedule for the provisioning of fibre which will be the same for all providers. ie first come first served.
Message 9 of 14
@birdy1978
I can literally see this turning into a right pot mess if you try and do anything before you move into the property.
If I were in your situation, I would wait until the house contract is completed and then place an order. Whether that is with BT, Plusnet or any other ISP, that’s obviously for you to decide. All I would say is, evaluate your needs properly and think carefully before you sign up to anything. Look at what’s on offer, cheapest isn’t always best etc.
Message 10 of 14
@Kimberlin Thanks
We have completion and move date of 20th August confirmed.
So do you think it would be wiser to let the current owners order close and for us to wait to make an order until we are in the property on 21st instead?
Assuming outgoing and incoming order at the same time may mess things up and make it even more difficult to go live?
Appreciate your help
Thanks.
