Message 1 of 11
Moving house no broadband
Hi I informed BT (9th)  was moving house on 26th Jan, the WiFi was disconnected at the old property that morning but it’s 6th Feb and I am still not connected at my new address
many conversations with call advisors have not resolved this, I was told last Wednesday that it is an unusual IT problem where my connection is stuck between two IT systems. I was reassured that now BT understood the problem it would definitely be connected by today 6th
sadly no WiFi today and no call back yesterday as promised. I have been given an EE mini hub but that won’t support 2 of us working from home. Need to work tomorrow and it’s past a joke
Hoe do I escalate this matter above the call handlers, they are pleasant but so far, ineffectual?
thanks
10 REPLIES 10
Message 2 of 11
Re: Moving house no broadband
@Cpanteli
This is just a customer to customer help forum, everyone here, including myself, are just customers.
The only BT Employees are the forum moderators. They may offer to help on this thread.
Message 3 of 11
@Cpanteli
While you are waiting for a reply, its possible a forum member can see if there is a potential issue.
What broadband package did you order for your new property, and was it just broadband only, or did you ask for a phone service which would be delivered by BT Digital Voice?
Is it a new build property you have moved into, as they are normally full fibre only?
Use the address checker for your address, on the link below, and post the results, but edit out your address details first, as this is a public forum.
Message 4 of 11
Thanks, appreciate your response. It’s not a new build house and it’s just a broadband package, no phone . I have moved from full fibre supply to traditional copper but I was told by BT this should not make a difference to supply except broadband speeds
Message 5 of 11
@Cpanteli
There may be an issue if there is no spare capacity in the local cabinet. Posting the results from the address checker, should indicate that, as it will show "waiting list" or "unavailable" against the top rows of the VDSL results.
Message 6 of 11
Hi, @Cpanteli I'm really sorry about the delay connecting the broadband to your new home. I'll send you a private message so you can get in touch with the moderation team and we'll be happy to find out whats happening.
Neil
Message 7 of 11
Just a small point (and I know this doesn't help restore your service) - the WiFi signal in your house is produced by your BT hub or router and is independent of the broadband service coming into your house.
You need BT to provide Broadband service at your new address which you can then access via either the ethernet ports on your hub, or via the WiFi signal that the hub generates.
Message 8 of 11
Ah I understand, thank you
Message 9 of 11
Thanks for sending over the details @Cpanteli
I'm glad I was able to get this sorted for you. Post again if you have any other problems.
Cheers
David
Message 10 of 11
Hi, I have the same issue as the OP. Just wondering how you managed to resolve this.
Andy
