Message 1 of 7
The My BT facility has been unavailable since April, so I can't access my bills. Is there any idea of how long it will take for the fault to be fixed?
6 REPLIES 6
Message 2 of 7
Re: My BT
There is no problem with the MyBT.
How are you trying to access it. Is it with the app or a web browser?
If the app have you tried un installing it and re installing it?
If a web browser have you tried clearing the browser's history and cookies?
Message 3 of 7
Re: My BT
Thank you; I am elderly and not very techy. All I know is that I was in contact with BT direct in April and May and was told it was a known fault. It's taking a long time to fix!
Message 4 of 7
Re: My BT
Did you re contact them per chance there was a fix which may have required you to do what I have said in order to implement the fix..
Message 5 of 7
No, I wasn't told to do anything, only that they did not know how long it would take to rectify.
Message 6 of 7
Re: My BT
Did you recontact them?
The problem was fixed fairly quickly for BT and they are not in the habit of contacting people to tell them that a fault such as what had happened has been fixed.
Try what I have already posted.
Message 7 of 7
Re: My BT
Issues with My Bt affected different customers in different ways. My understanding that customer support were supposed to have an escalation  route for customers  who were continuing to experience issues.
