Message 1 of 3
NOW Boost and Cinema
Hi,
I have a free trial for Now Boost and Now Cinema, which runs out shortly. Do I need to wait until the end of the free trial in order to cancel them? Thanks.
2 REPLIES 2
Message 2 of 3
Re: NOW Boost and Cinema
You can do it anytime from when the order completes until the day before renewal, you're not cancelling, you just switch off the renewal so they stop when the passes expire, you can reactivate them anytime as well.
Message 3 of 3
Thanks for the reply, Richie. That's great.
