Message 1 of 6
New Build home best package options
Any recommendations please for which monthly package for Broadband would be best value and to cover a 2100sq ft new build bungalow? Thanks
5 REPLIES 5
Message 2 of 6
Re: New Build home best package options
@Connor74
Use the address checker on the page below, and post the results, but edit out your address details first, but leave the exchange name and cabinet number showing. That will show what is actually available. Most new build are now full fibre, assuming that you registered your site with Openreach
Edit:- I see you have posted about his before.
https://community.bt.com/t5/Home-setup-Wi-Fi-network/New-house-and-Garage-connections-options/m-p/23...
Message 3 of 6
Exchange COALISLAND is served by Cabinet 5
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date
High Low High Low
VDSL Range A (Clean) help 28.7 21.5 3.1 1.8 18 Unavailable Available
VDSL Range B (Impacted) help 28.2 18 3.1 1.5 13.1 Unavailable Available
G.fast Range A (Clean) help -- -- -- -- -- Unavailable --
G.fast Range B (Impacted) help -- -- -- -- -- Unavailable --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
WBC FTTP Up to 1000 Up to 220 -- Available 1 Stage
Other Offerings Availability Date
VDSL Multicast Available
Exchange Product Restrictions Status
FTTP Priority Exchange Y
WLR Withdrawal Y
SOADSL Restriction N
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG premises served by 2.5 Inch plastic duct 56.
FTTP is available and a new ONT may be ordered.
As a fibre priority exchange, FTTP has priority over other products if available at the address
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
This site is in an FTTP priority area where FTTP is available but exceptionally SOGEA will also show as available to order but only at Non-Standard Premises (NSP) such as Hot site, Uninhabitable and Temporary locations. Migrations of WLR Solus (voice-only lines) is also allowed but only for SOGEA 0.5Mbps bandwidths. SOGEA 40/10 bandwidths order is also allowed.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Message 4 of 6
It says FTTP is available, single stage install, its also the priority option, so nothing else can be ordered.
Message 5 of 6
Just curious in terms of monthly packages, what would be the minimum/recommended download/speed etc you would order for a property this size , without spending too much for unecessary costs?
Anonymous
Not applicable
Message 6 of 6
There is no correlation between download speed & property size, it's entirely down to your usage. Unless you have a house full of teenagers gaming & watching 4k video while others are on Zoom calls all day, 150Mb is likely to be plenty.
How well a single router will cover your property, you won't know until it's in place. So I'd suggest not ordering any extras until you see how things actually work. Many new builds now also have ethernet connections running to rooms that can help with distribution.
