Message 1 of 5
New account not recognised
Can't add new account to old one, not showing in mybt and Can't see settings anywhere to add it.
Frustrating its been a week since service was added, Can't use bt wifi as says not opted in even though its showing up on modem wifi.
Could do with some moderator help here please.
4 REPLIES 4
Message 2 of 5
Re: New account not recognised
Hi, @lbj Thanks for posting, you need to log in on the website and not the app to add a new account.
  1. Go to www.bt.com/mybt and log in using your BT ID username and password
  2. Click on Settings and then Account
  3. Scroll down the page and you'll find the Add an account link
Let me know how you get on.
Neil
Message 3 of 5
Thanks for reply Neil, can't see settings on website either.
Message 4 of 5
@lbj I'm sorry the instructions are different when on a mobile web browser. Tap the grey bar that says 'Your account' then scroll down and click on the 'Manage' button underneath Your details.
Neil
Message 5 of 5
Neil thank you very much, everything sorted and showing how i want 👍
