Message 1 of 12
'No landline needed'
Right so want to change to BT fibre without landline. Don't want or need a landline -it's 2023. So why, when I go to buy a bt fibre package that supposedly doesn't need a landline, is the first thing I see something telling me I need to set up a landline for bt services? That's false advertising.
11 REPLIES 11
Message 2 of 12
Re: 'No landline needed'
First thing I see on the BT website ( after entering a postcode ) is ‘broadband only’ deals or ‘broadband and phone’ , one is around £5 cheaper than the other ( for the same broadband package ) so don’t know where you are looking
Message 3 of 12
@Bigmeuprudeboy
Welcome to this user forum for BT Retail phone and broadband customers.
Are you using this page https://www.bt.com/products/broadband/deals
That will give you a broadband service without a phone, if that is what you want?
You still need to pay for the cost of the line to deliver the broadband, whether its copper or fibre. That is included in the cost.
Message 4 of 12
Yes I'm using that
So if its no landline needed do you get this?
Message 5 of 12
Whats this then?
Message 6 of 12
are you sure you have selected the option of broadband only as that looks like broadband and phone option hence why asking if you want to port your number
you need to pay line rental which is included in the package price whether your select broadband only or with phone.  without a line you cannot get broadband whether that is copper or fibre.  this has been covered many times on the forum
Message 7 of 12
Positive I'm looking at broadband only.
So you DO need a landline to use bt fibre?
Message 8 of 12
I believe this check when ordering is used to see what physical line is there and status of that line.
The term landline here is regarding the physical line (which you need for the connection to be delivered to you) rather than referring to the voice service.
Message 9 of 12
you need a line to receive broadband whether that is copper or fibre otherwise how do you expect to get your router connected.  using the word 'landline' is synonymous with landline phone which is misleading.  you need a line
Message 10 of 12
That means you have to have a landline then??
