Message 1 of 4
Re: How do I remove an old Account from MyBT
Please could I have some help with the same issue? Also showing my old address.
Thank you.
3 REPLIES 3
Message 2 of 4
I moved your post to start own thread so you would get help as previous thread was marked as solved
Message 3 of 4
Hi @davidgriffiths39 and welcome to our community.
I can get the old account removed for you. Please check your inbox for my message and drop me over a reply with the details.
Cheers
David
Message 4 of 4
Thanks for sending over the details and for taking my call @davidgriffiths39 .
That's been removed for you now.
Cheers
David
