Message 1 of 9
Re: Openreach Address Database does not match that of BT
Hi,
I think I am having the same issue and don't know which is correct. Openreach says I can get a full fibre connection (and lists providers) but BT says I can't.
I'm in a rural village and none of these options came up when I moved here in April, so wondering if things have changed?
So can I or can't I?
8 REPLIES 8
Message 2 of 9
as other thread was marked solved I moved your post to start own thread
can you enter phone number or address and post results
Message 3 of 9
Thank you, @imjolly  and hello. Here it is
Message 4 of 9
that shows FTTP available so try phoning FTTP TEAM 08005874787 and they should be able to help
BT are on strike today and also on Monday but you can try tomorrow.  If you get diverted on to CS as FTTP busy then hang up and try a bit later
Message 5 of 9
Ok thank you. By 'help' do you mean to confirm it's available? Or to book it?
And why then did the bt.com checker say no?Screenshot 2022-10-19 at 11.23.57pm.png
Message 6 of 9
dslchecker shows FTTP available so you should be able to book by phoning FTTP Team
Message 7 of 9
Ok. Thanks. Still don't understand why it's different though.... Very confusing to us simple customers
Message 8 of 9
Firstly, congratulations on having FTTP available. That's great!
It might be that the ISP systems haven't updated yet to reflect your new FTTP status. Is it just BT who don't show FTTP products, or other ISPs also?
Message 9 of 9
Ah ok. I didn't realise with today's fast connectivity and technology that that could still happen, haha.
Tags (1)
