Message 1 of 4
Re: Remove multiple BT accounts from ID
Hi there - I have the same problem - think one of the accounts was created for BT Sports years ago, long before we started using BT for broadband. Can you assist in getting rid of it?
3 REPLIES 3
Message 2 of 4
Hi @tanktiger Yes we can help with that, is the BT Sport account causing problems?
I'll send you a private message so you can get in touch with your details.
Neil
Message 3 of 4
Yes it is the old BT Sport related one that appears to be causing the issue - I'll reply to the private message...
Message 4 of 4
Thanks for sending over the details @tanktiger .
That's been sorted for you now. Post back if you have any other problems.
All the best
David
