Message 1 of 2
Removing multiple accounts from my BT ID
Hi,
Can anyone help with Removing multiple accounts from my BT ID. I have requested this several times over the phone and no-one seems to be able to do this? Its stopping me using the Renew / Upgrade functions.
Thanks in advance 🙂
1 REPLY 1
Message 2 of 2
Re: Removing multiple accounts from my BT ID
Hi @mikefairgrieve and welcome back, it's been a while.
Sorry you're having problems getting the unwanted accounts removed. I can get that sorted or you. I'll drop you a private message now so you can send over the details.
Cheers
David
