Message 1 of 2
Romove old account from my BT ID
Hi, I need to remove an old account from my BT ID. any time a log in it only shows the old account when in the My BT section without the option to go to my new account number. I can however go to the new account if I select billing and usage.
Kind regards
1 REPLY 1
Message 2 of 2
Re: Romove old account from my BT ID
contact billing using message now and they should be able to help you
https://www.bt.com/help/contact-bt/account-and-billing/broadband
