Message 1 of 3
Sky contract ends at end of Sept
My sky contract ends at the end of this month and I wish to move from them. You contract for 2 yrs looks ok. How do I get to move only at the end of this month
2 REPLIES 2
Message 2 of 3
Re: Sky contract ends at end of Sept
If you are considering moving to BT , you can call BT 0800 800 150 ( freephone number ) or order on line ,( same as most ISP’s )  , the fact you are on Sky should make the change simple , unless you are on copper pair service with Sky and FTTP is now available in which case a new ‘full fibre’ line would have to be installed.
This forum isn’t a way to order BT services , it’s a customer to customer advice area , you can’t order BT from here , unless a BT Mod offers to contact you and guide you through the ordering process
Anonymous
Not applicable
Message 3 of 3
You should cut out the middle man and place your order with EE.
Same company, all residential customers are being moved there anyway and quite frankly behind the scenes is a mess in terms of systems and processes, so you might as well start where you will end up, if you know what I mean.
