Message 1 of 12
Switched from BT. New provider didn't inform them. Who is responsible for the bill?
I switched from BT to a new provider on the 17th September, but today I happened to call my old BT number and found it was still active and going to voice mail.
I queried this with my new provider but received no reply, however within 3 hours I received notifications from BT that my services have ceased and to return the router.
So, I can only assume my new provider did not inform BT until I mentioned it today (25th September).
The question is, would the switch have been backdated to the 17th September?
If not and it has ceased today (25th), who is responsible for the billing between 17th September and now?
Martin
11 REPLIES 11
Message 2 of 12
Re: Switched from BT. New provider didn't inform them. Who is responsible for the bill?
Short answer is you.
You need to take up the issue with your new provider.
Message 3 of 12
Absolutely, it's nothing to do with BT if your new provider didn't inform them.
Message 4 of 12
That is what I suspected.
However, by me I will take that as my new provider should be responsible and reimburse.
I will have to wait for the bill to take that forward then.
I wasn't sure if the switch could be backdated by the new provider telling them it was the 17th rather than today.
But I suspect it is not a person to person interaction but just a button press.
Message 5 of 12
Obviously you won’t know until you receive your final BT  bill the last charged for day of service , but why would any losing provider consider a backdated cease notification, clearly you pay until the service is removed , if that’s later than necessary (in a situation where a new provider was in control of the switch ) they are responsible, them compensating you is between you and them .
FIIW , something seems a little odd anyway , what did the notification from BT you received actually say ? , was this the first notification from BT about you wanting to leave ?
If your  new provider started providing you with service on the 17th September, presumably it was at least a few days before  , or possibly a couple of weeks before  when you contacted them (or they contacted you ) and you agreed to become a customer  with the starting date of the 17th September, as soon as that agreement happened (the new company giving you a start date )  , is when you should’ve got an impact statement from BT outlining the cost , if any , of leaving, in effect the ‘sorry you are leaving communication’ did you receive anything like that pretty soon after agreeing to join this other company , or is that what you have just received or BT if it’s the impact statement you may find your BT bill last date may not be 25th September.
It certainly seems like your new company didn’t use the appropriate switching service , are they an Alternative Network or are using Openreach network ?
Message 6 of 12
@Cathprotech  Purely as a matter of interest, how was the switch effected? was it using One Touch Switching service online, or did you call your new provider to effect the switch?
Message 7 of 12
I don't want to go any further as the answer is straight forward anyway.
But, I will explain a little more just for a bit of clarification.
I have moved from BT copper to FTP.
This was supposed to happen on the 2nd September and I received notification 2 weeks prior from BT with the standard 'sorry your leaving' etc.
That was all ok.
But when they came to fit the fibre, there was a problem with the ducting so it was delayed.
I was actually worried that BT would cut me off on the 2nd September as that was the pre-arranged switch date, but my new provider told me not to worry as they have to activate the change when I get connected.
A few weeks go by and the ducting cleared, fibre run etc. Engineer came and did the final install on the 17th September and unplugged my BT equipment as it was no longer required. My new provide handles the switch!
As I have not heard anything more from BT, I decided to call my old phone number and I was surprised to find it went to voice mail, which of course lead me to believe that my account had not been switched. As my new service was provided over fibre, then of course both services could be active at the same time.
Anyway, I sent a message this morning to the new provide asking if they informed BT of the switch (which is their responsibility as per the contract). I did not receive any reply from them, but I received emails from BT telling me the service was 'ending' and how to send back the router.
This is obviously a response to my new provider suddenly realising they had not done the switch, which leads me to the question of whether or not it would have / could have been backdated (bill wise) to the correct date.
And of course if this wasn't possible who would be responsible for the bill.
I understand it is my bill so I am fully responsible for paying it, but would my new provide be responsible to reimburse me, legally as per the contract as it is their responsibility to inform BT.
So, that's the story for your entertainment and clarity.
I will get my router sent off to BT as soon as I can.
(Indirect question, how can I make sure no private information remains on the router, is there a WIPE EVERYTHING button?)
And wait for the bill to see when the account ended.
Martin
Message 8 of 12
Supposed to be 'One Touch Switching' but they obviously forgot to 'touch the switch'.
I emailed them a query and ... see clarification message.
Message 9 of 12
there is a recessed button on back of BT router which if you press and hold for 20/30secs then that will revert hub back to factory settings and wipe your information
Message 10 of 12
@Cathprotech  I'm assuming then that you have not chosen to stay within the BT Group. I have used One Touch Switching myself to switch within the BT Group of Companies with no problems. I guess sometimes it works, sometimes it don't.
